orangecurry
Guest
- Joined
- 13 Mar 2008
- Messages
- 9,612
I do like a tyre-fitter that knows what he is doing - lining up the yellow dot with the valve to minimise the possible weights needed. :thumb:
hoggy993 said:Sorry Kim just realised I didn't answer your question
[/quote]wizard993 said:"Oh no, here we go again....
WhiteFlag"
...damm hoppy993 has/remains infected with the "HD Billie"(Monroe Strain) degenerative 993 suspension disorder
best try the spell again.....
"Look into my eye[hoggy993], look into my eye, the eye, the eye, not around the eye, don't look around my eye, look into my eye, and you're under. "
You will wake up in 10 secs and all this talk/debacle about HD Billies vs Monroe, Achtung, Orange Curry and Chris @Centre Of Gravity etc will be erased from your mind forever.
"3,2,1.....your back in the room"!!
hoggy993 said:Sorry Kim just realised I didn't answer your earlier question re the difference in ride between the two cars
This is my second 4S, first one was running Bilstein HDs and had a lower ride height (couldn't tell you exactly how low). Ride was very firm but it was great fun on smooth roads and very sensitive to steering inputs. The steering wheel did squirm a bit and there was some tramlining though.
The set up I have now is softer (but firm enough) and there is no tramlining. Its a less tiring drive and on balance I prefer it but that probably just means I am becoming part of the pipe and slippers brigade.........
Achtung said:This is my second 4S, first one was running Bilstein HDs and had a lower ride height (couldn't tell you exactly how low). Ride was very firm but it was great fun on smooth roads and very sensitive to steering inputs. The steering wheel did squirm a bit and there was some tramlining though.
So, Just to clarify..
Hoggy has personal experience of owning and running Porsche 993's with both Bilstein HS suspension and also Original Monroe suspension....
With the Bilstein HD setup he has found his car to be-
- Ok on dead smooth roads but too firm on normal roads
-The steering wheel squirmed
- There was tramlining
With genuine Porsche designed OE Monroe suspension he has found his car to be-
Just the right amount of firmness
- No Tramlining
-More comfortable
-Preferred choice
So there we have it folks, straight from the mouth of an owner who has sampled both!
Original Porsche specification Monroe suspension is the safest, most comfortable, outstanding performance package!
