Sundayjumper
- Joined
- 17 Mar 2009
- Messages
- 312
Set of Gaz coilovers + Compbrake top mounts.
Fitted on 7th July 2019, they've done one track day and a couple of hundred road miles. Great on track but horrible on the road. Solid top mounts make it all very unpleasant, lots of road noise, you can even hear the oil squelching through the pistons. It put me right off driving the car. I used it a bit during the rest of 2019 but hated them so much that from the MOT in Feb 2020 until now the car has been relegated to the back of the garage and has only done 149 miles in that time.
The fronts didn't fit into my hubs properly so I had to make up some shims - I have email from Brian at Gaz confirming that this has never happened to anyone else so I guess it's a only problem with my car and yours will be fine ? He also confirmed that it's OK to use a shim (that nobody else has ever needed to do), and that you need to remove the helper spring to get the right ride height.
The coilovers originally cost me £1,200, plus another £500 for the top mounts. Very rare to find second hand, especially with such verified low use. Looking for £1,200 delivered.
