Nordschleife
- Joined
- 6 Mar 2014
- Messages
- 22,195
Demort said:alex yates said:Mine reads low all the time. When the light comes on I've still 4 gallon in the tank. One thing I've never solved on my car.
On a C4 it calculates the last amount of fuel due to the saddles , which is setup by doing a calibrate routine .. basically you tell the car how much fuel is in the tank when the gauge is at a set point.
Has to be done with a tester though.
Yes I'm fully aware how Porsche do the tank calibration routine, but I'm not convinced that's the problem. If I fill from empty, the gauge should ping into action when it has 19 litres in (on the C4). Mine doesn't come alive until I put about 28 litres in - which is the offset that my gauge is out (around 9 litres).
