where.is.lee
- Joined
- 25 Oct 2021
- Messages
- 1
Hi all,
I've been struggling to remove my PCM 2.0 to install the MR 12volt bluetooth kit as the top 2 cams that retract the prongs/pins are broken or missing. As the plastic surrounding frame is in the way of seeing these pins I am unable to use a screwdriver or any tool to easily push the pins in to clear the plastic frame and slide the PCM 2.0 out. Has anyone successfully overcome this before without hacking things apart?
Thanks in advance!
Thanks in advance!
