Jeez, reading through this and thinking what a pain it is to try to resolve electrical issues now that cars have become so very complex. It was simpler in a time when you could just put a load test on a battery and read off a scale on the tester to judge the capability of the battery. Or you could disconnect the battery from the car`s electrical system and charge it. Leave it to settle for a couple of hours or so then measure the voltage accurately and dependant on the voltage found you could then determine the percentage efficiency of the battery. I have a cheap (old) unit that does this and displays the results by way of LEDs. The same unit can show results when connected to the battery in-situ for over/under charging, and cranking the engine as a form of load test.... ! Is it the case that such old tec, is confused when connected to modern batteries or systems..?
Pretty sure that the battery is called into immediate action to perform checks as soon as you try to enter the Porsche by touching the door handle, and that being the case it seems logical to expect voltage drop to some extent ...? To test the battery it seems best not to have it connected in the car..?
I guess the thing to remember about earths is the actual contact area of the connection, and how effective it might be...? While we tend not to like to see bare metal in our climate knowing well it attracts corrosion, good metal to metal contact is essential to provide a good earth at each and every point of connection.... Copper turning black at crimped connectors as you found Infrasilver, can be a sign that the crimp has suffered some corrosion or heat which increases it`s resistance to the flow of electricity and causes voltage drop when under load, slow starter operation, and reduced alternator efficiency to charge the battery given the same earth path is used for both functions, along with all the lesser current sensors, EFI and actuators which may show no signs of issues given their minimal current demand...?
Wherever a resistance exists in a high current demand situation heat will be generated, blackening wires, insulation, etc. etc. etc. An electric fire element is just a resistance, as is a light bulb both generating heat... Not trying to insult anyone`s intellegence, just that I try to keep it simple if possible to help ME understand.
I suspect it might help if you really clean the mating surfaces, and consider the area of contact carefully, no rusty bolt heads or washer faces, everything clean, then once connection is made to protect from corrosion taking hold, a smear of grease or paint over the whole area bolts,nuts, washers, seems like a reasonable idea..?
Of course even with a perfect electrical path to and from the starter, if the starter has poor external or internal connections at the solenoid, or the cable from the solenoid to the starter has corroded connections then the brushes in the starter and the condition of the comutator...
Yeah it can go on and on, though the confusion for me is why does the issue show up when warm...? It was ever cold and damp starts that put the battery under most load and created most issues in times past. :?:
