Hi All,
I'm sure it's nothing, but I noticed a while back that I had a bit of mayo build up inside the oil cap and wondered if it was serious?
I have had the car checked out by an OPC in Reading and serviced by an Indy back in November and everything came back 100% ok and I know the oil filler cap did not have anything on it then. However I did not use the car much over Christmas and if I did it was only for short trips. I noticed that some mayo had built up on the oil filler cap but I read on here somewhere that this can sometimes happen in cold weather when the car is not used much.
I had another look the other day when I topped up the oil and noticed the mayo had dryed out but it does look rather disgusting and wondered if I have a more serious problem I need to address?
Am I worrying about a common winter problem or should I be getting the car checked out again by a professional?
Any advise appreciated.
