dcapper said:I adjusted mine in the gear and I definitely got farther along. Make sure you check the switch on the windshield part too. Now I need to see what you mean about the clamshell switch in the back.
It's not the clamshell POT which determines roof position, it's a POT on the left hand hydraulic RAM. To get to it, you really need to take off the rear interior panel to the left of the rear seats.
The position of this POT is moved by an arm and a pin on the ram, so as the ram moves, the POT turns and the voltage changes.
PIWIS can show current voltage of both this POT (and the clamshell POT). You can move the roof to various stages of opening 1-6 and see if the current voltage falls within the appropriate of the 6 saved calibration values, which might range from 0.8V to 3.5V or similar. One of DeMort's documents on here shows the 6 positions of the calibration values.
