dcapper said:I love this info. I directly applied voltage to the drive motor. The spline gear is moving fine but the square centre pot isn't moving at all. When I checked the resistance after, it was still at 6.35k ohms. But if I manually move the lid, the lid moves fine without any binding and the connection where the motor goes spins. So I think the drive mechanism is fine. Although the top cable where the microswitch doesn't move at all. Maybe that only moves when the motor is driving it? Do you remember the repair kit part number you bought? Maybe I need that?
There are 2 repair kits, pre 2003 and post.
Pre
https://www.ebay.co.uk/itm/183896934521?hash=item2ad11c8879:g:E5gAAOSwrtFbUJ~i
Post
https://www.ebay.co.uk/itm/192602959382?epid=1516398578&hash=item2cd807ee16:g:E5gAAOSwrtFbUJ~i
I also had a quick look at the clamshell latch cable driven microswitch and you are correct. Mine shows open circuit when the switch is operated and closed circuit when the switch is not pressed.
