Hello, I've been having a couple of issues with my 996 Targa roof. The service history includes receipts, plus a USB with lots of photos, for some major work on the roof in 2018 at Precision Porsche which is encouraging. I was hoping that deMort or anyone else could help impart some wisdom please.
1st Issue:
When pressing the button to close the roof, the roof sometimes stops closing - releasing the button and re-pressing the button gets the roof to move again. This issue seemed to be more prevalent in colder weather. The issue also seemed to get better with more regular use of the rear hatch.
2nd Issue:
When the button to open the rear hatch is pressed, sometimes the hatch does not pop up. There is a sound from the mechanism when the button is pressed. Sometimes it seems to try to open it, but it can't, then it pulls it back to a locked position. I have to help it up by lifting from the rear wiper pivot to get it to open.
I narrowed down these issues to a problem with the rear hatch latch assembly and micro-switches. The part number label on the rear latch assembly is dated 2002 so it would seem to be original - I assume the micro-switches are original too.
I removed the rear hatch latch assembly and found one of the micro-switch levers was kinked out of shape so I carefully flattened the lever and reassembled.
The result is, the roof closes without stopping so far. But the rear hatch still, sometimes, does not pop open.
What do you think the likely problem with the rear hatch not popping open is?
1) Faulty micro-switch in the rear hatch latch assembly - purchase new micro-switch loom?
2) Lubrication of rear hatch latch assembly - what type of grease would you suggest?
3) Gas struts
4) Anything other suggestions...
Thank you!
1st Issue:
2nd Issue:
3) Gas struts
Thank you!
