Brake pipe to pad wear sensor - plastic clip
9xxnick
29 Jul 2014
314
Could anyone let me know the part number for the little plastic clips that attach the pad wear sensor wires to the hard brake lines on the 993? I've looked but couldn't find them in the PET.
I've attached a couple of pics to better understand what you mean. If you mean the white plastic connector on the end of the wear sensor then I don't believe you can buy it separately. It comes with the sensor. If you mean the tube connector then I believe that it is part of the braking wiring.
Hope this helps.
ATB :)
Sorry, it's neither of those. It's the small plastic clip, black in colour, which clips the pad sensor cable to the hard brake pipe so that it doesn't flap about and touch the wheel. There's one per caliper. If you look at in in cross section it's a little like a number 8, with one of the holes a bit bigger than the other to accommodate the greater diameter of the cable compared to the hydraulic line.
That's it - many thanks indeed! The 911UK hive mind triumphs once more.
124,620
1,442,154
49,051
porschezilla
