Mac68
Nurburgring
- Joined
- 11 Mar 2021
- Messages
- 377
Apologies for the long post. I need some pointers or advice please. I've recently had some "engine out" work completed a reputable garage. The works were new x-over pipes, rear coolant pipes and various items whilst I was at it, LTT, tandem pump, plugs, coil packs, AC condeners, TIP seviced, full service (filters) and new brake fluid, rear discs and pads.
Before pickup the garage rang to say it's throwing a Lamba error, I forget which one and asked them to replace it. After replacement the other one, on the same exhaust, errored too. Long story short the garage you can drive it and pop to have latest erroring one replaced at my convenience. The car was running fine for a couple of weeks until this earlier this week I had an issue starting it when cold. It started intially but seemed to drop it's revs really quickly from 1200ish to 800ish and then almost immediately to 600 at which point it was running really lumpy and wouldn't rev back up to 1000 and then proceeded to cut out. I tried a start it a couple of times and it wouldn't start and then the battery was flattened. I had been doing a lot of short trips and moving it in and out of the garage, whilst I worked on the garage.
I "assumed" the battery was kapout and that somehow the ECU wouldn't allow the car to run smoothly or properly without a decent battery, even after starting. I checked and the battery was nearly five years so I replaced it with Bosch S5 85.
The problem persists but only the first time I start the car for a "while", but I'm not using it enough to determine what a "while" is at the moment. It's not a daily driver.
One other thing, the garage fitted my used but fixed up (about to be Gundo'd) mufflers. The previous mufflers were shot and the joints and flexi joints had gone. I figured it was a good opportunity to get the old ones off and the new ones fitted with decent SS bolts etc.
Any pointers of what I should be researching would be really appreciated.
I have ICarsoft PORii OBD reader but don't really know what to look at.
The garage have said they'll have a look but I can't make it back for a while.
Thanks in advance.
Thanks in advance.
