Paul_S
- Joined
- 3 Mar 2018
- Messages
- 235
Re-opening an old thread just for some advice.
I was fitting new engine mounts yesterday, and after removing the Y-pipe and air box I need to move the intercooler to Y-pipe rubber hose out of the way a little. I noticed the left one was very loose, and with a very small tug it popped out from the hole in the rear wing and detached from the intercooler. After finishing the mounts, and with the hose simply pushed back in (I know there is meant to be a clip holding it in place), I went out for a drive to test out the new mounts but now with two things to check. I put the boost gauge on the dash and under full acceleration (in 2nd) I was only showing 0.3bar - I understand it is better to do this in 5th gear at 40mph full throttle so get a better reading, but under hard acceleration in 2nd I assume I should see a higher number?
I've felt the car was lacking a bit of poke, bear in mind I've only had it a month but it doesn't feel like the shove in the back I remember from my old one.
I've just bought some Do88 intercoolers and Y-pipe anyway, but keen to confirm if I have a boost leak before I fit them.
