Hi all, would appreciate some advice. I've been having cab top issues with my 997.2 Since March 2023.
I tried to put the roof down and it went off at an angle made an awful sound.
Took it in to the local main dealer and they originally said it was the convertible top lid drive gear. Replaced at an expense of £2.2k. Roof worked but it wasn't closing properly. The clamshell would sit flush on one side but leave about a 2cm gap on the other... So back into the dealer we go and they have another look change something again.
Works again but a few months later the cab top will now only retract 80% so even worse. It won't even go down.
Bring it in and they finally say that all of this is because the clam shell is deformed with the below response. They want £10k for the repair but willing to reduce to £6.5k for the inconvenience caused.
"Having fully investigated the roof and stripped the components down at initially our cost, we have found the clam shell is deformed which is causing the drive motor to fail, we believe this is due to the increased stress on the unit caused by the warped rear cover. I appreciate the vehicle has been back into us a couple of times for this issue; once the drive unit was replaced on both occasions the roof was operating beautifully and we had no further reason to further investigate. As this is now the 3rd time the unit has failed we have completely stripped the mechanism and found the root cause of the issue. I appreciate this has been an inconvenience for you, however you have not been charged for any diagnostic just the fitment of the drive unit originally"
I feel shafted because the original email was as follows suggesting they strip it down and so the underlying diagnostics:
"we would certainly need to strip the components down to make sure there are no other items broken, if everything is ok the cost to replace the Convertible top Lid drive gear is £2.2k"
Clearly that wasn't done. I'm now £2.2k out of pocket and facing another £6.5k bill when they should have diagnosed the issue to begin with.
What course of action would you take here? Are they negligent? Do I have a let to stand on?
Appreciate any advice.
