I haven't got round to doing anything with the centre console yet, I usually do painting in my garage at home but there is an engine in there at the moment, somewhat in the way, so I'll have to rethink on where else to do it.
There was an issue with the drivers door handle, it would stick in the slightly open position. So to get the window to go back up again it would have to be manually pushed in to place.
I wasn't sure what the problem was, so to make sure I had whatever I needed I bought a secondhand one in the correct colour for £20.
To get at it, make sure the windows are up and then disconnect the battery.
Remove the door card and peel back the membrane near the lock mechanism.
There is a metal bracket held on with three bolts which blocks entry, so remove that.
There are two nuts on the back of the mechanism which clamp it to the door frame, remove these, and also unclip the actuator arm. That is done by pulling back the plastic cover and pull the arm out the sleeve. Unclip the cable from the bottom of the rear cover. Undo the electrical connection for the microswitch.
The lever will then come out. Here you can see the old one and the new one.
From inspection it was clear that nothing was broken, but the rod which is used as a pivot was corroded which was making it stiff. The new handle was not in as good condition as the current one, so decided to swap the rods over than the entire handle. Undo the clip on the end of the rod and pull it out.
Here are the two rods side by side. The new one is massively better, but even so it was given a good wire brushing and lubricated to hopefully stop further corrosion in the future.
That done, put it all back together and test it. I now have a spare door handle and a working one on the car
Time taken 1.25 hours
Cost £20
So far:
Total time: 92.75 hours
Total cost: £6245.84
