Changed the n/s regulator at the weekend, worked perfectly while I adjusted. Buttoned up the door card and suddenly, nothing, the fuse had burnt out. Took apart and reconnected, burnt through 3 more, instantly fusing. Disconnected the electrical connector to the regulator and the re secured, worked perfectly again.
Worked absolutely fine since, then tripped the fuse again this morning. Replaced the fuse, works perfectly again.
I've checked the wiring, nothing obviously wrong. There are no screws of fastenings going anywhere near any parts of the loom....
I changed the regular on the o/s in the autumn and have done it before on my 986, normally straight forward...
I'm at a bit of a loss?
Anyone had this happened to them before?
