Space Cadet
- Joined
- 20 Jan 2022
- Messages
- 323
Thanks, will look into it
Super_Ray said:I think I am right in saying you are better off with 997 top mounts. Slightly improved, more readily available and therefore less expensive as a result.
Anyone else confirm as its something I need to do myself
thanks, Ray
Shalmaneser said:Paynewright said:I fitted a replacement M030 kit on mine (when you could still get them). I find it very slightly too harsh.
If I was changing them again I'd go for Koni Special Active dampers. Not sure on springs - near OEM spec and lowered a tiny bit probably.
There was a forum member posted recently who had fitted the konis and was very pleased with the set up.
Also, I think coil overs are a bit overkill for a mainly road car.
WRT the M030 I would agree, although at higher speeds and on track M030 is nice. I might be tempted to also go for a Koni/H&R or Koni/Eibach combo also. Often aftermarket springs are progressively wound so don't negatively affect road comfort much if at all.
Do the Konis get rid of the crashy low speed ride?
Space Cadet said:Have bitten the bullet this morning and ordered a set of KW V3's (and OEM top-mounts all round) through RPM Technik, will be possibly 8 weeks before they arrive but can't wait and will let you know what they're like once fitted....
The plan is to have them at their max height, which should only be c. 20mm drop.
porkchops said:Reviving this old thread as I am in a similar position for my c4s and have no clue what shock absorber to go for. I am on a tight budget just wondering how your setup turned out at the end? Happy? also like the oem feel but a touch sportier would not hurt. Can't lower and can't go too sporty where we live. Country road are not the best!
