Hi all,
Does anyone know anything about the rear ABS reluctor rings?
I got a bit of noise after pulling away from a dirty section of road earlier and have pulled up ABS and PSM faults. I reset PIWIS faults for..
0290 Speed Sensor Rear Left Implausible Signal
0287 Speed sensor Rear Right Mechanical Fault
Now after clearing, the noise happened again when moving forwards, after reversing. It's sort of a little clunk on the rear right side.
I've ordered a couple of wheel speed sensors for now, as they're dirt cheap, but the noise is pointing to the ABS reluctor ring, which the sensor reads for wheel speed, as not being in great condition.
Looking at the parts diagram, it does not seem to be it's own part, so must be part of the entire wheel hub, or wheel carrier.
Parts schematic here...
https://www.bellandcolvill.co.uk/deroure?qs=1&preview=1&make=3&model=33&groupid=4402
Has anyone changed these before and knows which part it sits on?
