I took this photo a few years back then went and lost it .. now found !
I had an engine out for work and noticed this .. its a replacement with gearbox in i suspect and quite a sensible one hence i'm sharing it .
Make up 2 pipes and join to one side of the gearbox .. all pipes are located in the brackets .. must admit i thought this was a clever solution and a wee bit better than perhaps running a pipe under the gearbox as i have seen mentioned here before .
Whist i can't condone doing something like this obviously i just thought i would share what others have done .
