***Non-Turbo 996 owners - Please read - IMS DATA REQUIRED***
Thank you.
date inputted: 12/12/17
member: willy
model: 996.1 C2
engine size: 3.4
purchase date: 03/12/12
date registered: mid 1998
mileage (at purchase): 112000
mileage (now): 138000
bearing (orig./replacement): Original - dual row
failure data (if applicable):
comment: Recent clutch\flywheel replacement with IMS inspection.
:thumbs:
member: Apl911
model: 996.2 c2
engine size: 3.6
purchase date: 11/2017
date registered: 01/04
mileage (at purchase): 67000
mileage (now): 67500
comment: idle is a bit wobbly. I plan to replace when I do the clutch.
member: Asterix_the_gaul
model: 996.1 c2
engine size: 3.4
date registered: 01/99
mileage (at purchase): 93000
mileage (now): 93500
bearing (orig./replacement): Original Dual row
comment: regular annual oil changes regardless of mileage in last 10 years of history, will continue this..
date inputted: 25/1/18
member: Jpitshanger
model: 996.2 c2
engine size: 3.6
purchase date: 10/2016
date registered: 2002
mileage (at purchase): 74000
mileage (now): 77000
bearing (orig./replacement): EPS replacement
failure data (if applicable): Had not failed. Smooth but slight play
comment: Clutch and RMS were being done so bearing inspected. Replacement not necessary but decided to do it anyway as gearbox was dropped.
date inputted: 05/02/18
member: SpennyUK71
model: 996.2 C4 Tiptronic
engine size: 3.6
purchase date: 03/02/18
date registered: 02/03/2002
mileage (at purchase): 40,000
mileage (now): 40,250
failure data (if applicable): N/A
comment: As a new 996 owner, I am scared to death that this little tinker is going to destroy my engine!! I have a small RMS leak and I am considering having this and the IMS replaced. However, this will cost me the best part of £1,800!!! Now I don't know what to do.
PS, hello from a newbie!
The safest option with what you currently have is when you have the RMS replaced, have your ims coverplate removed and check the bearing for any play. When you realise there's nothing wrong with it, ping off the outer bearing seal. By doing this, the bearing will then be forever lubricated by the engine oil and dramatically reduce any issue you may have. It shouldn't cost much more than what you'll be paying to have the RMS replaced.
There is no guarantee with ANY aftermarket replacement and engine builders like Hartech have regularly seen failed 'upgrades'.
Save your money and follow the above advice. :thumb:
Oh, and welcome to the forum - you're in a safe place here :thumbs:
date inputted: 03/04/2018
member: fot0 (tony)
model: 996.1 C4
engine size: 3.4
purchase date: 01/10/15
date registered: 28/10/98
mileage (at purchase): 94800
mileage (now): 99800
comment: Recent engine drop (myself) to repair cracked head B1. New IMS housing prior to purchase, decided to leave as is. RMS shows minimal weep nothing to concern me. Fitted magnetic sump plug as precautionary measure - see my blog on pcgb forum
date inputted: 17/04/2018
member: EGTE
model: 996.2 c2
engine size: 3.6
purchase date: 17/4/2015 (3 years today)
date registered: 04/02
mileage (now): 84000
failure data (if applicable): None
comment: Much happier engine on Millers 10W-50 than anything thinner.
member: Kingb4
model: 996.2 c2
engine size: 3.6
purchase date: 20/2/2018
date registered: 03/02
mileage (at purchase): 80000
mileage (now): 80600
bearing (orig./replacement): Unknown
comment: I have all past receipts and there isnt a record of the IMS being changed (they did the IMS seal in 2016)
IMS Survey
Date input 07/05/18
Member Jockmog
Model Carrera 2
Engine size 3.4
Purchase date 04/05/18
Date registered 01/07/2001
Mileage at purchase 74420
Mileage now 74570
Bearing Believed original
Failure Dat N/A
Comment This is really good work! I have only just purchased the car and I am thinking about a IMS and clutch change.
date inputted: 14/05/18
member: dombo
model: 996.2 C2 Cab silver/black
engine size: 3.6
purchase date: 06/05/17
date registered: March 2003
mileage (at purchase): 69000
mileage (now): 73000
comment: Last service Sept 2017 oil filter cut open and inspected for bits by specialist 9e. None showing. This will be checked every 12 months when serviced by 9e.
date inputted: 10/06/2018
member: eabeukes
model: 996.1 C2
engine size: 3.4
purchase date: 11//17
date registered: 17/03/1998
mileage (at purchase): 135000
mileage (now): 137500
bearing (orig./replacement): replacement
failure data (if applicable): Possible replacement 85k, 121k. Replaced 130k, unit faulty and replaced again at 137k
comment: Rebuilt engine at 137k due to cam timing. Internals still excellent condition.
date inputted: 18/6/18
member: Cybot7
model: 996.1 C2
engine size: 3.4
date registered: 02/01/2001
mileage (at purchase):29400
mileage (now): 30510
bearing (orig./replacement): Original. No mention of any major work in FSH
failure data (if applicable):N/A
comment: So far so good.
124,620
1,442,162
49,051
porschezilla
