eca02apc said:
Is 15 miles considered a short journey? I would've thought the oil would be up to temperature within that distance.
Too short according to the results.
Unfortunately, *just* hitting OP temp may not be enough, as you now have to recycle the first 14.9 miles worth of water vapour-oil mix in the engine extremities back into the main block.
Ironically, by running exactly to OP temp, you have produced the largest amount of water vapour with the coolest overall engine.
Basically, the Mayo is a physical byproduct (it isn't even chemical, as it is a reversible emulsion) of the design.
It is not dangerous (even if it looks unsightly)
A run of 30+ miles is required really during winter months (ie to OP temp + at least another 15 "at load" - ie it can't be pootling)
If you can't do this today, do it tomorrow, but it doesn't really matter - no harm from the Mayo will result (so you are right, for the GENERAL health of the engine, running to OP temp only is about adequate, although all components would, on balance, prefer longer)
The car is a tool also, and so it needs to fit into your life too.
I am not suggesting no TLC and use it as a white good (not even Jap boxes like that), but likewise, in this instance I am not saying do two laps of your daily run just to clear the Mayo.
It would be good if it did get at least a weekly (weekend) stretch though :thumb:
