Hi all.
I'm getting water leaking into my C4S. It's a coupe non sunroof model.
It's pooling up inside at the rear of the passenger side inner sill where it meets the rear wheel tub. I've removed the rear side trim and the water pool can be seen when looking in from the rear speaker aperture and the front seat belt anchor point.
I'm can't see any water tracks from the side window so I'm sure it's not that.
Drips of water are also coming in from the rear window at the bottom passenger corner, I have all that trim removed and the drip comes in from the inner structure at the corner.
I think both the leaks are the same source but depending on the angle the car is parked at it either pools at the inner sill or rear window corner.
I was initially thinking it was the rear window bonding but I'm not so sure.
Can it leak in where the roof rack points are?
Any ideas welcome as it's driving me to distraction.
Thanks ðŸ‘
Thanks ðŸ‘
