Boydyrs said:That's one I hadn't thought about......checking m8ne hasn't been upgraded already!!! Have to have a look tomorrow.😡😡😡
thefunkygibbon said:so, does it come 'out of the box' with normal mode settings and 'sports mode' settings and it works in the same way as it did before?
I assume you can, should you want to, tweak both of these "profiles"?
is it possible to have different profiles activated by different button pushes (ie hold down the pasm button etc)
T8 said:thefunkygibbon said:so, does it come 'out of the box' with normal mode settings and 'sports mode' settings and it works in the same way as it did before?
The standard setting comes on with the ignition. You select 'Sports' suspension mode by pressing the 'Sports' suspension button. It does its magic all by itself. In both modes you can feel it doing its thing whether you are accelerating, breaking, cruising and cornering.
The 'Sports' mode for the engine/gearbox works independently on its own button.
thefunkygibbon said:T8 said:thefunkygibbon said:so, does it come 'out of the box' with normal mode settings and 'sports mode' settings and it works in the same way as it did before?
got ya. pushing sports mode usually turns on sports suspension though, is that not the case any longer?
just checked and can only see the 1 thats relavent, wouldn't that be whats on the box by default already since its got 997.2 on the side of the unit in sharpie?jonttt said:check out the downloads section on https://www.dscsport.com/ for programming software and calibration files......nb most of these are written for american roads ;-)
