Hi all,
I'm finally getting around to wanting to fix the window not dropping issue I've had with my 996.
On the outside, pulling the handle a little bit activates the window drop, but as soon as you let go when shutting it's back up. Same happens if you're inside, glass drops and then immediately raises as you release the interior door pull.
If the windows down, door shuts fine.
Told it's the micro switch in the latch mechanism and it's easier to replace the mechanism.
Is the part number for this mechanism 8N2837016B ?
If I buy this unit - does it include the micro switches?
https://www.ebay.co.uk/itm/PORSCHE-...=p2349624.m2548.l6249&mkrid=710-127635-2958-0
And what's the difference to this unit?
https://www.design911.co.uk/fu/prod...E-Porsche-Boxster-986---996/?source=doofinder
Or do I just need the microswitch??
https://www.design911.co.uk/fu/prod127123/Door-Handle-Microswitch-Porsche-986-Boxster---996/
Feeling confused!
Feeling confused!
