Sundayjumper
- Joined
- 17 Mar 2009
- Messages
- 313
crash7 said:The first link is of the items I already have to mount the runners to the floor and these are the what I see as the weak point on my current setup, there are only 3 studs per bracket that from memory are around M6, I would rather them be M10.
Grind off the studs and drill your own holes to suit whichever side mounts you settle on. M8 is fine. I've just been through all this in my quest to get the seats low enough for me to wear a helmet in the car ! I ended up with:
The BK floor adapters that I linked to (wanted 6pt harnesses, couldn't find a better solution)
Generic side mounts (because I knew I'd be modifying them a bit, didn't want to ruin expensive ones)
Bimarco Futura seats (very good value for FIA approved seats, and taller than most seats)
Schroth harnesses (s/h because I don't need in-date FIA, Schroth because they're top quality, previous TRS ones were disappointing)
