toastyhamster
- Joined
- 15 Nov 2019
- Messages
- 27
Spent a couple of hours trawling through forums to find the answer to this, so apologies if this is a repeat but I can't find the answer.
My front end is in bits to replace the rads/air con condensers, while it's off I've tested the fans via jumping the relays and the drivers side resistor is bad.
The C4S/Turbo uses a different resistor to the standard 996 or 986, it is mounted on the back of the fan and has 4 wires in total going to three terminals on the OEM resistor. If I buy an off the shelf 100w 0.5ohm resistor from a component shop how do I wire it in? I understand that one of the wires may be unused as the turbo has a "medium" fan speed option which I don't need.
2 x Yellow/Black wire on one resistor terminal
1 x Yellow/Grey on one terminal
1 x Yellow/Blue on one terminal
My guess is the 2 Yellow/Blacks on one end of the resistor and one of the other two on the other end?
Also, related, all the fasteners were rusted in, anybody know where I can get the Torx head self tappers that the air con condensers are held on with? Annoyingly they're not on the parts diagram and OPC's are closed. Design911 drew a blank unless I can send them a picture.
