Battery change advice...
Richtw
27 Feb 2018
151
I have read mixed reviews/ reports of swapping the battery on a 997.2. Am I right in my assumption that I can simply swap the battery and drive down the road to clear the dash errors?
I have read mixed reports ranging from has to go on a PIWIS, all will be fine apart from the heated seats wont work, through to just do it and drive down the road it'll be fine.....
Anyone shed some light/ experience?
battery
Yep,
Just change the battery........i disconnected mine for about 2 months (2009 C2S) with heated seats while i was getting some interior retrimmed.......
Just plugged it back in and after the dash lights cleared everything worked fine, including the heated seats! :thumbs:
Thank you ..... much appreciated :)
Ill just point out the heated seats bit .. yes this can happen but more so with a flat battery and its still pretty rare.
Basically the heated seats will no longer work .. there are 2 other minor things that can also stop working but i forgot :oops:
Anyways if you ever get heated seats inop and have had a battery go flat or be replaced then you need a garage to do something called a vehicle handover with a tester .. all will then be well.
Reguards messages after a battery disconnect then a short drive will fix them.
Reset the windows though .. press and hold the up button with the window closed for 5 seconds.
Gen 2 997 and after fitting the battery turn the ignition on but dont start it or touch the throttle for 30 seconds in that time .
Battery swapped, no drama, pasm warning light which vanished after about 50m. Window reset. Job done :) oh and the heated seats still work :)
Recently replaced my OEM original battery last weekend. And like you all working well and messages cleared after a very short distance down the road.
Had to read the manual to make sure it wasn't like my 996 where you have to have the key in position 1 to stop the alarm going off :lol: (I was still cautious whilst disconnecting the terminal in case it rang out :what: :grin: )
Bosch S5 010 should do the job now :D
My battery is on the way out, (997.2) anyone know roughly how much the OPC will flease me for a replacement? (Still under warranty)
Nothing to stop me buying a genuine battery from OPC and fitting myself? OPC have said just call assistance, they will come out, get the vehicle to OPC and arrange a courtesy car, but I'll still have a bill, which will take the ownership costs up from zero :eek:
Just been quoted £180 plus vat plus fit from Porsche east London.
OPC Wilmslow 319.99 fully fitted, ***** it I'll buy a trickle charger :eek:
Just shy of £300 to supply and fit. Battery was £220 and half an hour labour.
Ouch. £77.39 for a Bosch S4 60 amp / hour with 4 year guarantee at ECP with discount code.
124,627
1,442,247
49,070
janders365
