Posting this as a separate item and not an edit ..
A 4 pin relay has terminals 85/86 .. these are the switching on / off of the relay .. terminals 30/87 are the connections the relay joins together ..
If you bridge term 30/87 it will be the same as the car doing it .. you basically bypass everything though .. by bridge i mean stick a wire across both terminals .. or a split pin .. it will get hot though .
In the case of the starter it will spin over .. make sure it aint in gear !!
Your emergency start if it all goes pear shaped .. as if this does not start the car then its the starter motor !.
You will still need ignition key in the on position .
EDIt .. a five pin relay will work in a four pin relay slot .
