Hello, I am a new owner of a 997.2 turbo S. I've been experiencing a couple very irritating problems that I cannot seem to figure out. Ive taken the car to a dealership and they don't give me a straight answer. Car has 13K miles.
First problem is some very fine white flake/dust that comes from all of the vents when they are blowing. It is almost like ash. The dealer told me they have no idea and to let it blow out naturally. They told me they looked at the aluminum fins on the evaporator and told me there was no oxidation of the aluminum.
Second problem is some water leaks into the passenger carpet, almost directly under the passenger floor vent. I noticed this today.
After some inspection, I found the foam covering (behind the battery) which the heater core tubes go through had a huge hole in it from a mouse. This hole is below the drain hole that is at the base of the center windshield wiper arm. There are also missing rubber grommets in the frunk area. This is the part :https://www.pelicanparts.com/More_Info/99970347641.htm?pn=999-703-476-41-OEM I don't know the function of these as there is still a hole for drainage in the bottom of them.
When the car is washed or if it rains, I suspect lots of water drains into that area where the heater core tubes run because of the hole in the foam. Im guessing that water can leak into the cabin from there (and perhaps dried detergent drying up and coming through the vents). Im also wondering if air to the cabin can get through that hole and bypass the cabin air filter.
The dealership told me that there is no connection to the cabin air through that hole in the heater core tube cover and if water got inside the hole, it wouldn't be that big of a deal and would not leak into the cabin. This is not consistent with what I've read online.
Any advice would be greatly appreciated.
Thanks in advance!
Thanks in advance!
