A few bits to report since the last update in Feb, I'm using it less and enjoying it even more, had a major service which has uncovered some issues, fitted a 3 spoke wheel, did a track day at Brands Hatch Indy (and understeered lots around Clearways), I'm part way through changing the discs and pads, shoes and handbrake cables, and it's booked in to have the "issues" sorted.
It had a fast road setup with Parr last year which I've been pretty happy with, and at road speeds there's no noticeable understeer. But on track at Brands Hatch going through clearways I couldn't find a way to manage the understeer. I am lead to believe a narrow track can induce understeer, and I have Carrera 3 wheels which are ET57 so 7mm further tucked in than 996 18x8s. I have another booked for later this month, it'll be interesting to see whether 10mm spacers make any difference.
I now see the logic in the 235s it was wearing on the front when I got it. If the spacers don't help, then when I next need tyres I will go back to 235s.
It went to Precision Porsche in May for a major service and spark plugs. They found a few issues, some of which I already knew about:
- the gearbox is whining and likely to be a main shaft bearing (I knew about this one, but nice to have it confirmed by those in the know).
- the front struts are missing the metal support ring.
- the handbrake cables and shoes need replacing
- 1 exhaust stud snapped (I knew about this), but it is now leaking (wasn't previously).
- and the shocker - the metal hex part of spark plug on no.1 has sheared, the spark plug is still functional, but cannot be removed. :frustrated:
The metal has sheared on the line below:
This is a pic they took of it with a borescope, but it doesn't show much.
I did the support rings before the track day, and took it relatively gently given the other issues.
I was hoping to drop the gearbox and take it up to Helical Gearboxes in SE London on the strength of Shalmaneser's recommendation, but work is ridiculous at the moment so I have booked it in with Precision again for:
- drop engine and gearbox
- strip and rebuild gearbox as needed
- replace all manifold studs
- remove spark plug (they are >50% confident this can be done without removing the head)
- change AOS, oil cooler, gearbox mount, and brake line over the gearbox.
It's going in mid-August, fingers crossed it doesn't need the head off, but if it does I'm already into it for so much that it has to be a keeper! We're having e a new shed put up later in the year so on it's return it can go in the garage too.
