starting problem 997
allybally007
3 Dec 2008
5
Has anyone come across this problem? I have a 56 plate 997 4s. In the last few months the car will intermittently refuse to start when the key is turned. The depress clutch pedal message shows up, despite the clucth being down. Eventually the car starts. I assume the sensor on the clutch pedal is playing up? I had a look without dismantling anything and found what appears to be a sensor switch which activates in the first few cm of travel but there must be another sensor which goes at the end of clutch travel. Has anyone had this problem? Is there an easy fix or a way of bypassing the sensor?
Thanks.
(p.s. what I really need is a Haynes manual!!)
Hello
You need to get it on the porsche tester to see the clutch pedal value and it will show whats happening..failing that just replace the switch probably around £10 -£15...
Mike
eventually found the switch sitting just beyond the cruise control switch. Have bypassed it and the problem has disappeared. Now just need to replace. Found a picture of the layout on renntech forum - seems to be more common on boxters
http://www.renntech.org/forums/index.php?act=Print&client=printer&f=74&t=13249
There is a picture on the website above. Two switches are present at the top end of the clutch lever. The farthest away is the interlock switch. The other tells the cruise control to disengage. I have bypassed the interlock switch as its position will presumably make it a ***** to change. In any case I would rather be without it. Have had no problems since the bypass.
124,618
1,442,149
49,051
porschezilla
