Been slowly chipping away at this.
First of all i invested in a set of quick jacks, probably essential in Porsche ownership, wish id bought some years ago
Porsche stuff by
Ross Elder, on Flickr
Porsche stuff by
Id decided to tidy up the garage a bit, paint some walls, fit new shelves, lay a floor which was all going fine till COVID-19 picked up pace. I was left with a fair mess in the garage but some tidy new shelves and fresh walls
Porsche stuff by
Porsche stuff by
Managed to get stuff back on shelves and get back at the car. First up (thanks to posts on this forum) was fitting new bearings into the idler pulleys. All for the princely sum of £27.
The pressing was fine, getting the pulleys out was painful. I ended up just dropping the whole cradle out and lowering the engine as far as it would go. Madness! Fitted a new Alternator belt once all the pulleys were back on and tightened up
Porsche stuff by
Then i fitted new 997 coil packs, new plugs and new coil pack heatsheilds
Porsche stuff by
Porsche stuff by
Porsche stuff by
Then my turbos finally arrived, ive been so busy with work id left them to quarantine for a couple of days then cracked them out and stuck them on the shelf. A marked difference to what i sent off.
Porsche stuff by
Then it was time for test fitting to see if everything still lined up ok as the chap basically rebuilt these blind due to condition.
Porsche stuff by
Porsche stuff by
Porsche stuff by
Porsche stuff by
With all being well, i blasted the sumps with compressed air to make sure they were clean, fitted new o-rings and bolted them up, then i could bolt the turbos to the car and set about making lines.
Started off by cutting the OEM line back to give me some room
Porsche stuff by
Then fitted the hardline to AN adapter
Porsche stuff by
Then made an insanely short line covered with heatproof sheath
Porsche stuff by
And a test fit, nice!
Porsche stuff by
Same again on the other side
Porsche stuff by
While i was in there today i thought id test fit my new exhaust, hope it sounds as good as it looks
Porsche stuff by
Porsche stuff by
Getting there.
