infrasilver
Moderator
- Joined
- 4 Oct 2010
- Messages
- 9,934
alex yates said:infrasilver said:........and my idea, in this order, was to take most of the sidewall of the bush away as this is not really needed and see what result that brings.
I was thinking about this last night and why the sidewall is the thickness it is. It then dawned on me that they're that thickness as the distance across the outside faces of them when both inserts are fully depressed into the mounting bush are the same width as the carrier that goes over them. This is so that the outer faces act as stops and prevent the inserts from moving out from the apertures in the bush, thus ensuring they are fully encapsulated in their designed position.
Mine do seem to be less 'vibrant' since I fitted them on Friday. Think they'll be getting left alone for the foreseeable future and see what happens.
Edit: Sorry Chris, I'm presuming you meant thinning the walls down of the inserts? Correct me if I'm wrong.
Yeah they are that thickness to hold the insert in place as you say but I think there is probably too much on them just to replicate the original outer rubbers shape and I don't think it needs that much. I was thinking of cutting it down to the diameter of the actual bush so there is just a circle of poly and as this will be minimal to the NVH I may then chop off one of the insert sections off and see how that is.
