Guys, here's my maintenance history on my 2002 996 Turbo. Just had a big bill which has made me think about how much I've spent on it in total in the 2.5 years and 11000 kilometres I've had it.
Bought it at 127k kms. It was in good condition but had obviously been a daily driver for the first few owners, as is the case with these cars. I bought before prices and interest rose. All the paintwork is original but there is the odd blemish and normal interior wear. Had a PPI before buying which revealed a sound car in need of some basic exterior and interior cosmetic work, which I've been plugging away at (I won't include the cost of this here). PPI also revealed the car needed a set of tyres and pads/discs, which was factored into the price and done when I first bought the car. Since then I've done:
- CV joint replaced due to torn boot.
- Battery X 2 - it's hot here and these don't last well.
- Instrument Cluster #1 - oil level warning failed. Changed the sensors on engine (at cost) and was eventually traced to a bad cluster. Avoided a huge bill by sending it away to be repaired.
- Alternator - it was the original. Think the voltage regulator failed, which caused my second instrument cluster fault due to a spike in current. Was weak anyway so replaced with a new unit.
- Instrument cluster #2. As above, had the batt/alternator warning on permanently. Sent off cluster (again) and had it repaired at reasonable cost.
- Rear shocks leaking - replaced with OEM bilstein.
- ABS Pump - had all other possible causes of my ABS PSM warning investigated and turned out to be the pump. Ordered a remanufactured unit from Bosch. Half the price of porsche unit but still expensive!
I've also done a load of little bits like frunk and engine lid struts, new mats, spacers, wheel refurb, seat belt reel, new keys, interior phone delete and probably a few other things. Added a stainless exhaust. These were either inexpensive or unnecessary.
PPI and service history shows it had a recent clutch, various suspension bushes and engine mounts shortly before I bought it. I've been doing regular oil changes and drive with mechanical sympathy and make sure everything is warmed up and cooled down etc.
I only do street miles, mostly of weekends. Bought a Subaru BRZ for the track but tempted to sell and use the turbo; just concerned it'll get costly with more mechanical failures.
I'm assuming I'll be looking at rads, turbos, spoiler rams and suspension parts at some point in the future.
Not begrudging spending on a bit of maintenance on what was a very expensive car when new. Besides it's risen 50% in value which has made it a pretty cheap hobby. Love the car anyway.
Have considered changing the car for a Cayman R or 997.2 C2S. On looking at both, the Cayman R just wasn't a 911 but I am tempted by a 997.2. Not as special but a bit newer and quite fancy a PDK. Could just be buying more trouble though and going through a similar process.
How have the rest of you compared to myself in terms of mechanical failures?
