missfire
18 Mar 2006
213
my car has just started to feel lumpy on tickover and also seems to miss when you are holding the revs up around 5,000 and on a few occasions after pulling away from stop it would not rev over 3k anyone got any ideas it is booked in to the dealer in 10 days time just hope i dont get another huge bill
the car is a 2003 996 c4s
Migration info. Legacy thread was 53006
Take it to a good indie close by - it should be a straight forward fix. Could be something as simple as a ignition lead breaking down. Whatever you do, don't drive the car until it's fixed though!
Migration info. Legacy thread was 53007
just collected the car from opc but they said they have pluggged it in and there are no problems who knows maybe it is me
Migration info. Legacy thread was 54770
I had similar problems on my two previous Nissan Skylines, missfire at high revs.
Cause was failing spark plug. You should get it looked at (again) as this missing could cause more damage.
Migration info. Legacy thread was 54829
if the miss doesn't log a fault in the engine management then they won't find anything.
I would have thought the engine check light would come on if the fault was logged as a missfire.
My 98 c2, had a missfire and the check light came on, but then went off, the fault was still logged though.
maybe using a rolling road would help identify it.
Migration info. Legacy thread was 55111
coil tower or air mass sensor take it to a opc centre and they will plug the pewis tester on the car
Migration info. Legacy thread was 56313
Previous poster said:
see that you finally got around to registering :wink:
Migration info. Legacy thread was 56792
Sounds like abuse of Moderator's privilages or DPA violation - unless you already know Sid :eek:
Migration info. Legacy thread was 56794
it's back they said there was no fault showing but you know your car it seems to be ticking over lumpy but bournemourh opc told me this is correct and i think it is holding back after 5000 rpm. It has been in again since for the loss of oil pressure which was a crank shaft seal repaired under warranty but i think they only replaced it as they had the gear box out a few weeks before to replace the fly wheel and clutch and more than likely caused the damage
Migration info. Legacy thread was 56822
Stu, though you went to last Autumn's curry nite?? Sid was there so you know him too. :wink:
Migration info. Legacy thread was 56824
Migration info. Legacy thread was 56945
124,629
1,442,261
49,072
geoff993
