I have a 2012 991. The interior map lights stopped working and needed a new panel.
Mine had two buttons on it in addition to the left and right panel light on button. It had the Parking sensor off button and an off button to stop the map lights coming on when they door opened.
The replacement one only has the Parking sensor off button.
It was a straight swap and it works. However the map lights do not come on automatically when you open the door - only tiny LED in the middle. They do work when you press the button to turn them on.
Is the panel operating correctly or does it need coding of some sort?
thank you
thank you
