I am currently locked out of my 996C4S, it is in sleep mode but the key won't open the car. The battery and key fobs are fine, the car is asleep but I can't open it with the key for some reason, a new lock was fitted recently (not by me) and I suspect not checked that the key opened the door afterwards. Even if the battery was flat the key should open the door, it doesn't.
I can't get access to the boot to disconnect the battery and reconnect it to get the fobs working as I can't get the arch liner off without removing the wheel, I can't remove the wheel as the locking wheel nut is in the boot. I am not therefore able to get to the emergency cable to open the boot. Happy days.
If I can get the RAC to get the door open I can open the boot in the normal way and I assume I can disconnect the battery, re connect it to reset the sleep mode? Once I can operate the car I'll be taking it back to the workshop and get them to sort the key/lock situation for correct fitting etc.
I'll let you know how I get on.
