Following on from my tip woes, I have at a least a working car. Timeline below
Lock up weak, so either low fluid, bad eds4 solenoid or torque convertor seal. I wanted to sort it as weak lock up means, slipping clutch = contamination & heat.
1. (Jack, drain, remove sump, replace sump, refill. run till 35C check level lower) Change fluid and filter and test solenoid resistance.
Still poor lock up
2. (Jack, drain, remove sump, replace sump, refill. run till 35C check level lower) Disconnect lock up solenoid to stop it slipping
Flashing tip lights, no gears, it detected fault.
3. (Jack, drain, remove sump, replace sump, refill. run till 35C check level lower) Replace three solenoids with 'good used'
Now a new problem, when changing from 3rd to 2nd, it goes into neutral for a couple of seconds before thumping into 2nd,,,, now undriveable.
4. (Jack, drain, remove sump, replace sump, refill. run till 35C check level lower)
Decide to get the solenoid body professionally overhauled and tested so send it off to valve bodies for repair.
Still poor lock up
