Well I have managed recover my car back home this afternoon after paying the £234 diagnostics fee. Unloaded the car off the trailer and as it was only 4 o’clock I thought I would have a quick look to see if I coils find the fault. Firstly I removed the DME relay gave it a shake and a tap but no improvement so I then checked the 2 fuses under the steering wheel and surprise a 3.5 amp fuse had blown, I replaced it with a 5 amp fuse and everything is OK. Just to make sure I hadn’t just moved a lose or broken wire I removed the fuse again and the original problem came back so I know it was the fuse. Don’t know whether to leave the 5 amp fuse in or put a 3.5 amp back in. Now need to find why the fuse l
blew. It only took 10 minutes to fix and that included trying to find a spare fuse. Note to self, do not use an OPC Porsche dealer again.
