How to test horns?
thesmithsUK
Nurburgring
7 Dec 2014
385
Is there an easy way to test whether a horn is working?
Just liberated these from the car this afternoon.
The spade connections all seemed OK (at the wheel hub and the horns themselves). And the fuse is intact.
One of them occasionally works. But only occasionally.
jump leads on your battery and the other ends on the spades. Makes sure you do + to +
As said put earth and 12v through them and that will test if they work or not.
I had an issue with one (low tone) on my 996, thought it had broke so bought a new one, bumper off and fitted it to find it also didn't work, traced it to the connector having a bad connection.
When mine have seized up or sounded like a throttled cat, I've just sprayed a load of wd40 down the spout and let it soak for 10 minutes. Always brought back to life.
Protect your ears before testing....
Armed myself with a digital multimeter...
Switch at steering wheel - fine. Fuse - fine.
One of the tones is dead (no continuity, no sound when wired direct to battery). The other one is intermittent. Cleaned up the connectors, tested (positively) for continuity, also worked when connected direct to battery. So, connected it back up - and it worked. Twice. Then nothing.
Disconnected it. No continuity. Took it apart. Reassembled it. Tested (positive) for continuity. Back in situ. Worked. Once!
Though I guess I could get my soldering iron out and try this: http://p-car.com/diy/hornrepair/
I'm minded just to order two new tones!
Yep - that's what happens when you don't squirt some wd40 down the spout to free up the farty bit inside.
Also helps if you adjust the tone screw whilst testing but you need to leave the horn blasting whilst you do it. Shove a rag down the spout so not to annoy the wife or neighbours.
Will give that a try now...before I spend £140!
Have taken the trumpet off and opened the unit up. Might actually give this a try before ordering new: https://p-car.com/diy/hornrepair/
Magic919 said:
That sound expensive. Dearer than 997 horns.
Bet they're not Porsche specific, anyone know what other cars share the same horns? Is there a part number on them?
Hmmm...half the price. Tempting. But what would the purists say?! At least they'd hear me coming.
There are cheaper still on ebay if you want to experiment.
124,633
1,442,327
49,079
JPD
