alex yates said:I mean using the end of the plank as the pivot point about a foot or 2 under the car, not using it as a see-saw like in the photo.
DerbyJim said:alex yates said:I mean using the end of the plank as the pivot point about a foot or 2 under the car, not using it as a see-saw like in the photo.
Sorry, being thick... how does the wood lift the car up without a pivot point?
Pip1968 said:Derby Jim, I have had the same sort of problem as I jack my car up on out gravel drive. I usually find that jacking her up further and then just brushing the debris away will sort it out and allow the jack to drop fully. Just watch your hands :wink: . A brush or stick may assist if your risk threshold is low.
Best of luck.
Carrrera Monkey is probably smoking something esp. as "evar" does not even feature in the new OED. :dont know:
Pip
alex yates said:Jim, did you see my post at the bottom of the previous page? Do you get it now?
DerbyJim said:The piece of wood / pivot approach I think would've been difficult. Not sure how long a lever you would need to lift it (someone with a bit more time and physics capability should be able to tell us.
DerbyJim said:I went up to the car earlier and dug the trolley jack out. Luckily the ground was quite soft from all the rain otherwise it would've been firmly stuck.
The piece of wood / pivot approach I think would've been difficult. Not sure how long a lever you would need to lift it (someone with a bit more time and physics capability should be able to tell us. Plus, I had no confidence that it wouldn't have damaged the sills of the car so gave that a miss.
Alex - happy to try it on the Beemer shed that we have but if it happens on the Lotus then I just lift it up with a spare hand! :grin:
