Hi Guys
Please help. Last week I fitted some new rear tyres which are Falken in the standard size same as removed but obviously not N rated. I had seen mixed reviews but thought I would try them. They have been on a week now so 500 miles and pressures are correct.
The issue I have is the traction light comes on and the power cuts or the brakes cut in when not require. Typically this happens on a bend when at steady speed or when slowing down into a bend. Strange thing is when accelerating out of bends it does not happen.
Any thoughts on what to try should I increase or decrease pressures? Should I get new front tyres to match the Falkens or should I just get some continentals like I had before?
Or could it be something else like a damaged or failed sensor or component?
Winny
Winny
