Hi as per the title the battery warning light came on today and a message on the dash saying Warning battery / generator. Managed to get home with no problems and on restarting message appeared again.
The manual wasn't much help suggesting it may be a broken drive belt or a fault in the charging system but no loss of power steering or rise in temperature so I'm thinking it's unlikely to be a broken belt but will check this evening.
The battery has been connected to a Ctek trickle charger for the last few weeks with no sign of issues although I believe the battery is at least 7-8 years old. The car is a 2003 Boxster S manual with 50K miles.
I'm guessing it could be the battery or possibly the alternator or I understand there is a voltage regulator. Any idea what order I should get these investigated / changed or if there is anything else I should be looking at.
