Hi All,
Driving along in my 964, noticed that my radio had turned off and I could barely see the digital display on the gauge, so potential power issue happening, slowed down for a set of lights, noticed that the car was misfiring. Pulled away and then silence, car was dead and wouldn't restart, bollocks.
Had to push the car into the middle reservation of the bypass with idiots beeping me. Had a bunch of roofers ask if I needed a hand but I was done by then, thanks to them anyway. So, I checked battery connections, swapped DME, checked fuses, poked about in the engine, just making sure nothing weird has happened blah blah, but nothing had, tried starting loads of time but nothing, lights on the dash but no starter solenoid clonk or anything..
Called out my old man as I was just 2 minutes away from him, tried jump cables but no luck.
Manged to push the car to a safer spot and called the RAC, plugged his booster on and the car fired up better than ever. Removed the booster, wouldn't start..
Ok, I may have killed the battery by trying to start it X times. I have a battery isolator on the car, the battery is disconnected every time I finish with the car. He suspected it could be that causing an issue (is a cheap ebay thing), removed it and tried to start car again but no good.
Got the car running again with the booster, he tested the alternator output while the car was being revved, 13.3v was max output.
So, I need to pretty much charge my battery and do a few load tests to see if it's knackered or if the alternator is duff. The alternator was a refurb part, just before I bought the car, I haven't done more than 1000 miles since.
I have no idea what was refurbished inside it, the old voltage regulator may have been used for all I know. But, with the RAC booster on the car, the car just felt so much nicer to drive, I felt like the gears changed faster (tiptronic) , the revs didn't drop and it just felt like it wanted to go, like a sport mode, felt sharp. As soon as the booster was disconnected and I moved the car, it felt lethargic.
Any tips on things that fail or areas to check? 13.3 sounds low to me but for all I know, might be normal on the 964. Bad earth, which one?
I have left the battery on a CTEK charger over night and I'll see how the car behaves, any further help would be appreciated.
I was fortunate enough not to have taken my 1 year old out with me like I was about to, I really can't have the car letting me down like that with him in it.
Cheers!
Cheers!
