Phil 997 said:
mark pearce said:
as the miss fire appears at 39800 revs
could it be something to do with the vario cam mechanism?
Mark thanks for the though , vario cam issues have been discussed and will be looked into as we are not getting any codes so we just need a process of elimination , what I am trying to avoid is spending 2k on sensors ,solinoids and electrical bits to then find its an engine drop anyway , but the dam painfull bit is the other option is to drop the engine to then find its a £200 electrical parts :nooo:
This is one of the reasons i think its the cam or crank hall sensor. Because theyre magnetic induction sensors they can send the correct voltage for part of the range and not throw an error code, if one of them isnt counting right and the crank and cam counts dont fit, the ECU is going to start throwing a wobbler. This explains both why it happens at certain revs, and why it seems to move from one cylinder to another each time
Disclaimer: i dont know much about these engines specifically but i do know a bit about ECUs, sensor systems and canbus
