I just replaced my front and rear windscreen rubber seals and I thought I would share my experience because when researching into this job, there was a lot of incorrect information on the net and I had to dig deep to find the correct way to do this.
Firstly, there are two seals to the windscreens: there is one under the glass that holds the glass in place and one that is a top weather-proofing seal that needs to be replaced if the rubber has aged and hardened. The top seal slots into the bottom seal with a hook type friction fit. There is advice on the net that the old seal needs adhesive to be stuck back on and this is incorrect. There is also feedback that the window needs to be removed, which only is needed if the bottom seal is broken. As long as the top seal is doing it's job, the bottom seal should be fine.
The seals I bought from Design911 and were not too expensive or hard to find. When I removed the old seals, I spent some time removing crud under the slot of the rear screen bottom seal: water and crud was collecting there and could have eventually eaten through and caused hidden corrosion. As for fitting the new seals, I needed some silicon lubricant and it was a simple press fit. A simple job that took a few minutes to do.
