ELA
- Joined
- 30 Aug 2011
- Messages
- 1,424
It's turning out to be a major mission just to get the engine out, having to cut up parts of the chassis and disassembling far more than I should have to in order to get clearance. All the front chassis bracing, air-ducting and oil cooler parts have to come out in one: much head scratching to find the best solution required. Still it gives an opportuning to redesign everything that has been disassembled so that it will be far easier in future. This picture also highlights just how far back in the engine bay the engine sits; like a front mid-mounted config: No.1 cylinder is basically inline with the front axle. This is what has led to the almost perfect weight distribution 51:49. With all the changes I've made to the car it may even be 50:50 now as a lot of weight has been removed from the front end:
