ABS light
Jack D
5 Jul 2011
214
Hi, I'm after help in trying to solve a problem, my ABS light has decided to stay on, at first the light was coming on intermittently, but now it's on all the time.
Any ideas ?
Jack
From memory it's usually either a sensor or alternator issue.
My came on when the alternator belt gave up the ghost.
I'm sure someone will be along soon with a more convincing answer though.
There could be other causes, but my recent experience was that a faulty wheel speed sensor (one per wheel) causes the ABS control unit to switch the light on immediately before and after starting the engine.
If the light only comes on when the car gets to around 4mph, then the wheel speed sensors are electrically OK but are dirty, resulting in there being no or a corrupted signal to the ABS CU.
The sensor are not especially expensive but are generally a pig to remove from the wheel hub, sadly.
Use a Porsche compatible OBD diagnosis device to read out the fault code in the unit. This will probably point you directly to the problem.
Cheers,
Tore
Thanks for the replies.
I've just connected a ohmmeter to each wheel sensor, the rear o/s gives no reading at all, so I'm presuming this is the most likely culprit?
The other issue I've just noticed is that the odometer has also stopped working, the speedo works fine, could these two issues be linked ?
Jack D
Jack D said:
Thanks for the replies. The other issue I've just noticed is that the odometer has also stopped working, the speedo works fine, could these two issues be linked ?
Jack D
Probably not related, odometers tend to stop working around the 100k mark usually because of a worn Gear wheel, speedo usually follows.
There is a do it yourself fix, but most people send the speedo to Julian Reap.
http://www.reapautomotivedesign.com/index.php
Jack D
I had my speedo odometer repaired last year. I found the guy on Ebay UK, he did a good job, was knowledgeable and did a quick turn a round. The contact is :
[email protected] his name is Rick. No affiliation by the way.
The total cost including shipment to Spain was £90.00 I think the repair was £75.00.
ATB :)
The rear abs sensors you now have to buy in pairs from porsche main dealers.
The old type have been discontinued, the new type apparently are wired differently and need to be replaced in pairs....a pair from porsche will set you back just under £400.
Sourcing the old type is proving difficult, especially in the uk, I've found a parts dealer in the states who still has a few genuine ones on the shelf.
Jack D
Jack D
ATB :)
:thumb: :thumb:
Jack D
You have to replace in pairs (if you have old version) because the sensor bars in the new version are 90 degrees different, so I guess there would be a slight signal mismatch if you only replaced one on an axle. I replaced my rears and sourced from Promax Motorsports - less than £50 each.
I have tried them, unfortunately they're closing down the business....
just going to start drilling out the other sensor, no doubt that one is seized in as well.
Jack D
Jack D
That's a shame - they have been handy for several parts over the years :(
Yes, it will be seized!
Just an update...
New rear sensors fitted and no warning light !
If your ABS light comes on, use a multi meter and check each sensor, simple test to eliminate or pinpoint a defective sensor.
Jack D
Hi
Well done drilling then out. I have done this more than once and its a job I hate. I also burn them out a bit to help them along the way. At least the new ones ate plastic rather than metal bodied and do not seize in place.
All the best
Berni
124,620
1,442,162
49,051
porschezilla
