ochayethen00
- Joined
- 7 Aug 2021
- Messages
- 65
Ended up taking my crankcases and heads down to Hartech. Looked into various other options but they cover so many bases and with such a good reputation it seemed a no brainer in the end.
I'll be getting all 6 liners, heads reconditioned, IMS bearing (I have later shaft), vapour blasting the heads and crankcases, reconditioned pistons and small end bearings replaced.
I'm putting the crank carrier back together now. Does anyone know if there is an orientation for the small holes on the crank carrier oil squirters? And do they fit tight or slide around in their chamber? I'm using new OPC ones. I thought they would positively seat in the chamber but they slide back up to the shells when tilting the carrier over.
