Porschekit
- Joined
- 12 Aug 2014
- Messages
- 1,049
Hi All,
Thought I'd ask for some feedback on this;
Previously I had both front and rear discs, pads and accessories all changed at the same time with brand new parts.
After a period of time and on a recent minor oil service my local indy advised that the rear discs were 'heavily' corroded but "only on the inside surface of each disc" , yet the outside surface of each was shiny. Both fronts are fine and shiny.
He advised that this is common trait of the 997 model and that upon braking, the rear calipers trigger first and grip the disc setting the car forward momentarily and then the bulk of the work is done by the front brakes.
I thought it was a fault that the calliper wasn't pushing the pad on the insides, and therefore not gripping the inside of the rear discs, yet the outside of the disc is worn and shiny.
Anyone else have experience of this and is it a trait of the model?
deMort over to you .... :grin:
thanks all.... :thumb:
