Hi all,
As I've posted before recently my car went into Wrightune to have various works done and an MOT. Given the more than 2 year gap this time due to covid between services the list has mounted....
so far:
New aircon pipe/rads and condensors
caliper connecting pipes and flexi on all 4 corners
front driveshaft rebuild
secondhand PSE boxes fitted (i sourced)
so expecting a tasty bill.....
I also asked them to investigate a knocking from the nsr of the car over bumps at lower speed. Seems this could be engine mounts, top mounts etc.
I've asked them to replace the engine mounts with original OEM given at 85k miles and the movement on the car when blipping the throttle they must be pretty worn. It may not solve the issue but seems a good idea in anycase.
OEM are £160+VAT each side plus an hours fitting. I've seen lots of threads on engine mounts, my car is purely road driving so any reason not to go OEM?
Cheers,
giles.
so far:
Cheers,
giles.
